Maximum overbore gen 6 502 >
Old 10-11-2002 | 07:16 PM
rws's Avatar
rws
Default Maximum overbore gen 6 502
How big can a gen 6 502 block be bored?4.530 ?
rws is offline
Old 10-12-2002 | 07:58 AM
traviss's Avatar
The gen 6 502 block should only have a max bore of 4.500".
Travis
traviss is offline
Old 10-12-2002 | 08:28 AM
rws's Avatar
rws
Travis, that is what I read on the Gm Performance web site.But that is not what I want to hear !I think It will cleanup at 4.510 but that means a set of expensive custom pistons.
rws is offline
Old 10-12-2002 | 08:36 AM
mcollinstn's Avatar
can't you sleeve the bad hole?
mcollinstn is offline
Old 10-12-2002 | 08:41 AM
traviss's Avatar
Get your hands on a sonic tester and see how much wall thickness you have and too see if the bore is perfectly centered in the cylinder. You might be able to get away with it.. but like mcollinstn said.. slap a sleeve in it...
traviss is offline
Old 10-12-2002 | 09:46 AM
Mr Gadgets's Avatar
Charter Member #601
I have a gen V 502 that we took out to 4.520" was told at that time I could go to 4.530" but ex-engine man did me a favor and only went 4.520" so I would have a .010" clean up cut down the road.. now the pistons were custom and so were the rings.. gapless. Took for ever to get them. So think about it. Sonic check and look at the 4.530" and if not.. sleave the bad hole(s).
Good luck
Dick
Mr Gadgets is offline
Old 10-12-2002 | 09:53 AM
4.500 is the GM recommended maximum. However, many shops bore them to 4.530 with no problem. If it's a good block with no core shift you'll be good to go. It's best to sonic test it first to be sure.
Bob
bobl is offline
Old 10-12-2002 | 05:49 PM
after the work is done i would hydro the water jackets just to be safe. about $90.
excaleagle42 is offline
Old 10-13-2002 | 10:26 AM
Default Gen VI Block --Boring
RWS. According to GM's Performance Catalog, the Gen VI can be safely bored to 4.60 while still maintaining a minimum wall thickness of .325
Steet is offline
Old 10-13-2002 | 12:22 PM
traviss's Avatar
street- I am curious where you found that info.. My catalog (2002) says the production block can go 4.5, the only block I see that can go 4.6 is the bowtie block..
Thanks bro
Travis
traviss is offline
