Timing curve for superchargers >
Old 05-18-2017 | 10:59 AM
Default Timing curve for superchargers
Got my 588s with the 900sc/10-71 blowers and chiller on them. 9.25-1 with brodix alum heads etc. anyone have a recommendation on how much timing to run. I have the adjustable Daytona ignitions thanks in advance
prostockcat is offline
Old 05-18-2017 | 11:26 AM
Personally I wouldn't go more than 30-32 to start and gradually make changes. Nice you went with the Daytonas. Lots of flexibility. I'd think you'd want a short curve with an initial around 20. PM mild thunder and see what he ended up doing. He's got 420 MB's with Daytona ign also. How much boost you plan on running?
getrdunn is offline
Old 05-18-2017 | 11:28 AM
6-7lbs. The motors before this were 9.5-1 and 38 @ 55-5800 rpm. All same stuff just more Comp and no blowers
Old 05-18-2017 | 12:02 PM
I'm not familiar with the daytonas as of yet however will be soon. Are you able to set the start/crank timing also? Btw Id initially aim for 6psi with 9.25:1. Maybe a little conservative but better than the alternative.
getrdunn is offline
Old 05-18-2017 | 12:14 PM
Although come to think of it icdpple on here was running same blowers with chillers if I recall at 9:1 static and seems like he was throwing 8 or 9 pds of boost at them. You could do a search on his 548's and see the details to be certin.
getrdunn is offline
Old 05-18-2017 | 12:18 PM
Is that his name on here it's not coming up. It would be good to chat with him on jetting tooo
Old 05-18-2017 | 03:13 PM
I would keep max between 28-30 at first get the tune AFR's right work on timing after
ezstriper is offline
Old 05-18-2017 | 07:23 PM
Here you go. I screwed up on spelling.
http://www.offshoreonly.com/forums/s...ci-motors.html
getrdunn is offline
Old 05-18-2017 | 08:17 PM
You are right in the ballpark, 28to 30 degrees with an afr of 11.8 to 12 @ wot.With a 9 to 1 motor your effective comp ratio is 13:1 with 8 lbs of boost. you better be running race fuel.
Boxer is offline
Old 05-18-2017 | 08:56 PM
SB
Originally Posted by prostockcat
is that his name on here it's not coming up. It would be good to chat with him on jetting tooo
ICDEDPPL in cap letters
SB is online now
