Sea strainer Question >
Old 05-23-2017 | 04:47 AM
Default Sea strainer Question
I just had sea strainers installed in my 33 Outlaw that has twin HP 500's. I notice the starboard side sea strainer circulates a lot more water inside the strainer than the portside strainer when running. I was wondering if this is normal? Thank you in advice for any advice!
Mtb_05 is offline
Old 05-23-2017 | 04:59 AM
Did you rebuild both sea pumps when you installed the sea strainers?
endeavour32 is offline
Old 05-23-2017 | 07:24 AM
I don't think they rebuilt the sea pumps when they installed strainers. They didn't mention doing that when I set it up to have them installed.
Mtb_05 is offline
Old 05-23-2017 | 11:44 AM
The difference could be the water impellars. One being old and worn vs. the other being new.
I can tell you on our boat we have a similar situation. They both flow well but one flows better than the other. We just re did our impellars and can tell you they were both like brand new.
Only thing I can think of is plumbing coming into the strainer. One is a little longer and has more of a bend than the other. Just my guess.
1MOSES1 is offline
Old 05-23-2017 | 12:18 PM
Thanks for the info. I just ordered 2 new rebuild kits for the sea pumps. I'll see if that changes anything, but I'm pretty sure it's an indication the impeller is worn. This is a new to me boat so I don't know when they were changed last. So might as well start there for piece of mind.
Mtb_05 is offline
Old 05-23-2017 | 07:14 PM
and back flush the coolers and the water line into the strainer from drive. unless it comes right thru the hull like a sportfish.
dereknkathy is offline
