Bow Stop Question
I would stick with white carpet,,I have the Grey D style stops and they kind of suck,,once your bow makes contact with the stops you can not winch the boat up any more because it wont let is slide at all,,and it still marks the boat,,not as bad as the black stops but it does leave some marks.
I put buffing bonnets on current boat trailer V block. Previous boat, wifey would spray down the (Myco) grey rubber D blocks with Quick Detailer, prior to loading the boat. That worked well.
I'm trying the bonnets this year, although we'll probably forget and leave them on in the parking lot, and somebody will snatch them up!
Jim,
Before you retrieve the boat, spray the V-block down with this:
http://www.liquidperformancedirect.c...uct-p/0140.htm
I suppose any spray wax would work, but I've been using that forever. You coat the V-bunk stop with spray wax, and it acts as a lubricant. Any residue that is left on the boat is just wax, and wipes right off with a microfiber towel.
