27 Fever 1999 500 MPI gph rate?
Does anyone have a fuel consumption curve for a 500 MAG MPI Fever?
I just bought a used boat & the fuel sender is out of it and I want to estimate GPH till I get it fixed.
It is a 65 gallon tank and that is the reason I bought a formula. If you are on it like running a poker run you will need to top it off once and hour or you will run out . If it's anything like mine the boat will starve for fuel when it is on plane before it is actually empty . At wot you can easily burn 50 gallons an hour. Jeff
