WANTED  Carrillo 6.385" H-beam BBC rod (split set) >
Old 05-29-2017 | 05:19 AM
Default WANTED Carrillo 6.385" H-beam BBC rod (split set)
Hi
looking for split set of Carrillo H-beam BBC rods 1-2 rods would be fine
I have weighed mine at its 818 grams (28.18 ounces)
I was informed mine were Carrillo rods, or could be other brand
26097 written on side of rod if it helps,
Please advise if some one recognizes them
please send PM
brett fiddes is offline
Old 05-29-2017 | 08:24 AM
If you do find out what brand they are ( I can't see your pics for some reason) you can call and order the amount you need with the desired weight probably from the manufacturer. I had to replace 2 Crower I beams in my drag race motor, called them up and they sent out 2 the exact weight to match the others.
Tahoe540 is offline
Old 05-29-2017 | 04:27 PM
sorry about having issues with uploading not sure what happening
https://photos.google.com/share/AF1Q...dZT0ZwZUJMdXFR
Old 05-30-2017 | 09:36 AM
TomFTM's Avatar
I think they are eagle rods , most guys that spend the money on carillo's use the carr sps bolts. it says carillo on the bolt. Also you are gonna need the big end weight and the pin end weight . You will need a rod balance scale for that , not just a regular scale . I would call carillo and eagle and give them that number on the rod and see if it works.
TomFTM is offline
Old 05-30-2017 | 04:16 PM
Tom
Thanks for the reply
over the weekend had a decent look at the rods, and I was miffed a little on the ID, **** they all look the same to untrained eye
So as suggested fired a note off to CP-Carrillo with pictures hoping they would ID the rod
Yes they came back and advised the rods were in fact Carrillo, however someone had down graded the rod bolts to ARP2000
The rod part # on looking for is Pro-H
C 427-7685H which comes with WMC bolts
The weight is 814 grm
Although on Carrillo website it lists bob weights as:
WMC bolts: 807/570/228
Carr bolts: 815/587/228
So sounds like to get everything correct I need the Pro-H rod and change all the rod bolts to suit, although I need to accurately weigh the rods I have and check bob weights which will do latter this week as need to pick up crank from being machined
ARP 2000: 220ksi
Carrillo WMC: 220 ksi
ARP L19: 260 ksi
Carillo Carr: 285 ksi
SO HAS ANYONE ANY SINGLE RODS?
Old 05-30-2017 | 04:57 PM
Just wanted to test new software out, thumbs up
Old 05-30-2017 | 05:16 PM
just heard back from CP-Carrillo and have some additional information
fantastic customer service and technical support
The rod alone can vary 10 grams over different batches.
Those rods you have were made in 2004
WMC bolts weigh 38 grams per bolt
CARR bolts weigh 41 grams per bolt
Not sure what the ARP2000 bolt weighs
Taking the bolts out of the rod we have, gives a rod only weight of 738 grams
anyone out these with some off 6.385: carrillo rods????
Old 06-11-2017 | 06:25 PM
ttt
Old 06-12-2017 | 06:54 AM
I have a set of supposed to be Manley I beams at 6.535. $100 if you could make them work.
jmoore1225 is offline
Old 06-12-2017 | 01:39 PM
I think you are going to be hard pressed to find just 2 rods. I have a set of 6 Oliver rods sitting on a shelf for this same reason... like another poster stated, you can't use total weight. You will need the big end and pin weight. Good luck!
jamontes is offline
