Silent Choice Drifting to "Off" >
Old 06-01-2017 | 12:57 PM
Default Silent Choice Drifting to "Off"
My 27' Fever 496 ci silent choice activates just fine, but after a minute, or so, it goes off. Anyone know if this is fixable? Thanks!
Feverishly is offline
Old 06-01-2017 | 03:34 PM
Look at the air pump and you will see a fitting on the side of the pump. This is an over pressure relief valve. Take the valve off the pump and you will see it has a nut and spring on the inside. The valve may have some trash on the seat or, like in my case the spring just got weak and I tightend the nut to put more pressure on the spring and
Bama is offline
Old 06-01-2017 | 03:35 PM
fixed my problem
Bama is offline
Old 06-01-2017 | 03:50 PM
When you look at the pump there is a 4 way block. one port is screwed to the pump and the other two have hoses hooked to them and the brass fitting with nothing ho
Bama is offline
Old 06-01-2017 | 03:51 PM
hooked to it is the valve.
Bama is offline
Old 06-01-2017 | 04:10 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Some systems are air actuated.
Some systems have electric solenoids.
The solenoid controlled systems can and do have solenoids that fail over time.
Sydwayz is offline
Old 06-02-2017 | 12:12 AM
Default Thanks for the Info
Thanks...will approach as you two kind folks advised.
