Maximum overbore gen 5 454
Hi can't find any good local deals on a good used 502 so I was wondering how big I can have my 454 done? I know that the old Mark 4 Hi-perf 4 bolt blocks they take 100 over is this safe on a newer gen 5 boat block? Thanks Charlie
well standard bore is 4.25".. so i would think .060" is all i would want to bore.. so 4.31" You might be able to go bigger if you check it with a sonic tester and make sure you have enough meat, plus to make sure your bore is centered in the cylinder. If it was me i would just go .030" to clean up the bore. That would leave you another .030" for cleanup if you scatter the motor.. You don't gain much by enlarging the bore...
Travis
Travis
ddabal
Do It Yourself, Boating on a Budget
5
07-08-2008 01:40 PM
