Why Upside Down Oil Filter? >
Old 06-06-2017 | 06:35 PM
Default Why Upside Down Oil Filter?
Why does Mercruiser mount oil filters with the open end pointing down? I've tried searching for the answer but haven't found anything conclusive. I'm thinking of changing my remote oil filter to right-side-up to make filter changes less messy. Is there any advantage to upside-down? If not, why does Mercruiser do it?
---rick
RickVicik is offline
Old 06-06-2017 | 07:34 PM
---rick
I always wondered the same thing until I heard of the trick on here. When doing a filter change, loosen the filter slightly but do not remove it. Let it sit a few minutes. By venting it with the loosening, all the oil in the filter drains back into the pan and you actually wont spill a drop when you remove the filter. Works like a charm.
Gimme Fuel is offline
Old 06-06-2017 | 07:44 PM
rak rua's Avatar
I would have said the open end down makes changes less messy because the filter will be drained? There's probably a more scientific answer relating to the flow of oil and catching 'dirties' in the filter but it's Mercury, so who knows........?
RR
Quick edit: Above post makes sense. Like it!
rak rua is offline
Old 06-06-2017 | 07:54 PM
stab it with a screw driver on the bottom of the filter,which is up.it drains nicely,,now the ones that are horizontal,they can get messy.
sutphen 30 is online now
Old 06-06-2017 | 10:13 PM
This is the trick I recommend too. In either filter orientation, they will spill oil when removed.
Trash is offline
Old 06-06-2017 | 10:23 PM
Huh. Now I'm jealous that mine is open end up, lol.
Baja Rooster is offline
Old 06-06-2017 | 10:31 PM
bck's Avatar
bck
Charter Member#568
But you can fill yours up with fluid before installing it, so that evens up the score.
Straight bottoms and flat decks
bck is offline
Old 06-07-2017 | 01:52 AM
i was just wondering about that, lol. I guess you have to spin on the inverted units dry. Merc doesn't seem worried about it though.
Old 06-07-2017 | 06:24 AM
F-2 Speedy's Avatar
Clearance ? in most applications there is something mounted right below the filter head
F-2 Speedy is offline
Old 06-07-2017 | 07:46 AM
I`d rather have upside down, at least it drains out with a hole at the top .
Mine , not so much
ICDEDPPL is offline
