GM 572 Crate motor
In Chevy HighPerf mag. GM Perf Products will release a 572 crate motor in 620 and 720HP levels. Price not yet available.
620hp@5500, 650tq@4500, redline 6000, CR9.6:1, 10.200", hyd roller 254/264 0.632"/0.632", 118cc alumn rect heads, 2.25/1.88 stainless valves, dual valve springs, alumn roller rockers, single plane intake, 850mech secondary HEI, 92 octane.
720hp@6250, 685tq@4500, 12:1, mech roller,266/274 0.714"/0.714", 4500carb 1095cfm, race fuel.
I think this is the motor. Not sure when its due out.
http://www.sallee-chevrolet.com/Sneak/Previews.html
572 C.I.D. - 9:1 Compression Crate Engine Technical Information
Horsepower 620 @ 5500 RPM
Torque 650 Ft. Lbs. @ 4500 RPM
Max. Recommended RPM 6000 RPM
Compression Ratio 9.6:1
Block New! Sportsman Tall Deck Bowtie Gen VI
10.200" deck height
Bore 4.560"
Stroke 4.375"
Crankshaft Forged 4340 steel
Connecting Rods Forged 4340 steel, H-beam style, Shot peened
Pistons Forged aluminum, Full floating wrist pin
Piston Rings Plasma-moly rings
Camshaft Hydraulic roller
Valve lift: .632" I, .632" E
Duration @ .050" 254Ί I, 264Ί E
Lifters Hydraulic roller tappet
Cylinder Heads Aluminum rectangular port
118cc combustion chamber
Intake Valves 2.25" Stainless steel
Exhaust Valves 1.88" Stainless steel
Valve Springs Dual valve springs
1.540" coil diameter
1.800" installed height
197 Lbs. seat pressure
Spring Retainers Hardened chromemoly steel
Rocker Arms Aluminum roller rockers, 1.7:1 ratio
Push Rods High performance one piece
Intake Manifold New! Aluminum tall deck single plane
4150 series carburetor
Carburetor 850cfm, mechanical secondary
Rear Main Seal New! One-piece design
Windage Tray New! Screened and louvered
Damper High RPM torsional damper
Distributor H.E.I.
Ignition Timing 36Ί total advance
Spark Plugs R42XLS
Fuel 92 Octane
nice+nice
10.200" deck height
Bore 4.560"
Stroke 4.375"
Distributor H.E.I.
Spark Plugs R42XLS
Fuel 92 Octane
nice+nice
