1988 Baja force 235 temperature
I recently changed my impeller in my water pump have more water and colder water coming out of the starboard side than the port side temperatures running between 150 and 160 think I got all the pieces out of the hose going from the waterpump to the oilcoiler was wondering why or what to do to correct this problem.
If you've noticed this while it's running on the garden hose it's normal . The same thing happens on my 502 on a hose . To even it up I have to clamp down the stbd line to the exh manifold then it's fine .
You don't get full water pickup unless the boat is in the water .
