Go Back  Offshoreonly.com > Owners Forum > Activator
89 27' Prop Selection >
Old 06-18-2017 | 06:41 AM
Default 89 27' Prop Selection
I'm helping a friend dial in his 1989 27ft Activator. The boat is currently set up with an XR and a Bravo lower with a LWP. The motor is a 565ci making approx 650hp. The prop shaft is approx 3.5" below the bottom of the boat and we are currently spinning a labbed 28" Bravo turning approx 5600rpm at 80mph, 19% slip!! The prop does't want to carry the bow! I'm thinking trying a 27 or 29" Mirage Plus? This is a non-step hull with the inner strakes running only a few inches from the the transom, certainly dont need to lift the transom! Any thoughts from people experienced with this hull would be appreciated.
TomR is offline
Old 06-18-2017 | 07:49 AM
I'd try a box stock bravo prop first.
Unlimited jd is offline
Old 06-21-2017 | 11:24 AM
We ran boat with new 28 Bravo, slip down to 14% from 19%, now 83.2mph at 5500rpm. Good improvement! next we are going to try a std lower gear case as opposed to the LWP. Last fall with a stock 28 and stock lower the slip was closer to 10%. The only thing that changed from last fall was more power in the motor. We shall see?
TomR is offline
Old 06-22-2017 | 06:09 PM
Only thing changed? Xz versious Xr?
shaun harrington is offline
Old 09-27-2017 | 02:01 PM
Where did your friend end up?
TxHawk is offline
