h20 psi relief location
I was curious if insted of changing all my plumbing on the backs of my intakes would it be acceptable to add a water psi relief to the 1-1/4 hose after my lube oil cooler and before the inlet on the crossover? Or am I looking at this from the wrong angle and I have to put the reliefs on the back of the intake? If I do have to put them on the intakes is it acceptable to plumb them into the tail dumps? I read one thread where someone mentioned a psi issue related to the h20 alreading coming out of the tails. Thanks.
Wonder where that dumps to?...
At high speed the sea stainer will have more pressure than the motor any relief should go overboard. Just keep in mind sometimes high water pressure can be an issue with restrictions on getting water out of the motor. So dumping or relieving water before the motor doesnt make much sense, just raise the water pick up if you can. ? how much water pressure do you have
Thanks, it sounds like your talking about two different reliefs in the above statement, both methods I'm familiar with. Could you take a few pics to clarify?
