Good and bad on melling mel 0-10778 HV oil pump >
Old 06-24-2017 | 09:30 AM
Default Good and bad on melling mel 0-10778 HV oil pump
Just pulled apart oil pump on my 540 before closing up oil pan. Found worn rotor shafts and groves in side of pump housing.This was a worked hi volume pump. My question is my engine is built with the bearing clearance on the high side of at or near .003. Definitely going with a high volume but wonder about the new melling with the non cavitate groovs. Will oil pressure be low at idle?
TwoKs is offline
Old 06-24-2017 | 09:38 AM
Oil pressure will be too low at idle, may not be damaging, but very uncomfortable when the alarm goes off and the gauge reads 5-10
Unlimited jd is offline
Old 06-24-2017 | 09:55 AM
i use a lot of the 10778 pumps and imo it is the pump you should use,forget about any others.
mike tkach is offline
Old 06-25-2017 | 11:25 PM
phughes69's Avatar
I use the same pumps in my turbo motors and have no problems
phughes69 is offline
Old 06-26-2017 | 09:09 AM
The 10778 C (anti-cav) will have very low oil pressure at idle.
Louie is offline
Old 06-26-2017 | 09:29 AM
I have this pump in my drag car (565) and my boat (548) and do not see low idle pressure in either. Hot in my boat with 20w/50 idle is still 45 psi plus. I also read about the low pressure at idle but I have not experienced it in my applications.
Tahoe540 is offline
Old 06-26-2017 | 08:23 PM
What RPM idle are you guys running with this pump
TwoKs is offline
Old 06-27-2017 | 08:00 AM
IIRC I was idling around 600-700 and clearances were toward the large end of Merc specs.
Louie is offline
Old 06-27-2017 | 08:17 AM
I am idling around 850
Tahoe540 is offline
Old 06-27-2017 | 09:12 AM
Thanks for info guys
TwoKs is offline
