29 foot fountain Fever single vs. twins >
Old 07-05-2017 | 01:34 PM
Default 29 foot fountain Fever single vs. twins
I thought I seen some discussion on this in an earlier thread, but I can't find it. Just wondering, besides the obvious cost of maintenance and weight, what are some of the advantages and disadvantages? I am looking for maybe a 29 or 27 Fever, and am leaning toward the 29 because of extra cockpit area, but now am looking for comparison between engine setup.
StClairRaceFan is offline
Old 07-05-2017 | 08:57 PM
rak rua's Avatar
A 29 single will outperform a 27 with the same power. Don't ask why, it just does! You also get a touch more room and a bigger gas tank.
Single Vs. twin in a 29 is a mixed argument. I like the idea of twin small blocks in the later models (about 2000 up?) but the earlier ones, some had twin big blocks and they were very stern heavy. If you're hoping to run very fast, the handling has been questioned and that may be why Fountain switched to small blocks for the twin setup. Twins will get you on the plane a bit quicker and a touch more top end, that's about it.
RR
rak rua is offline
Old 07-05-2017 | 10:21 PM
Even the later model twin small blocks are way to tail heavy. 29 single is such a better balanced and performing boat it's not even close
precisiondetails is offline
Old 07-06-2017 | 06:41 AM
Single IMO. There's a reason they're harder to find than a twin 29'..........
TBAG is offline
Old 07-06-2017 | 07:08 AM
The simplicity and economy of a single is a wonderful thing. If you feel the need for twins for open waters etc you'd probably want to be 33'+ anyways.
Baja Rooster is offline
Old 07-06-2017 | 10:26 PM
The twin 29' will chine walk badly above something like high 80's. They also had reversion problems due to the weight making the stern sit so low in the water
Boatlesss is offline
Old 07-10-2017 | 01:35 PM
dirtlawyer's Avatar
I had a 29 with a single 525SC. The boat ran well, but was difficult to get onto plane with the factory set-up. We ended up swapping the lower for a -2 IMCO and added longer K-planes and that made coming onto plane more manageable. Part of the problem with mine was that the 525SC did not have a lot of low-end torque, but once it was up and running, it ran great. I would definitely take the 29 over the 27 as others have stated. Hope this helps.
dirtlawyer is offline
Old 07-10-2017 | 01:55 PM
I cant believe no one has brought up the fact that the 29' with twin LOVE to sink. To much weight in the ass end
otis311 is offline
Old 07-10-2017 | 05:10 PM
I know of a Fountain you may interested in. It's a super clean 10 meter. Give me a call and we can talk about it.
two four eight 840 621three.
Greg
GS42fun is offline
Old 07-10-2017 | 06:20 PM
What is reversion?
conneroutlaw is offline
