Go Back  Offshoreonly.com > Owners Forum > Powerquest
Boats dies at idle >
Boats dies at idle
Boats dies at idle
Old 07-08-2017 | 07:22 AM
Default Boats dies at idle
Help..... my boat would not start. I replaced the fuel pump, wrapped the fuel lines, new ECM, distributor, plugs, and gas. The wire set was not replaced yet, as 1/2 of them were too short. Boat started up, however, once warmed up, when I went to dock, the boat dies at idle, in or out of gear. The timing was bouncing between 8 degrees, at 6, not staying steady in place at 8. '95 Powerquest, 454 Mag, EFI. I'm stumped where to look.
t10bender is offline
Old 07-08-2017 | 08:13 AM
Have you checked the IAC valve ?
JaayTeee is offline
Old 07-08-2017 | 09:19 AM
I have not. Retried to do the timing this a.m., however my timing light must of shot craps. I'm lowering boat shortly and hitting the local marina. Bad apart about being at LOTO, to far into town......
Old 07-08-2017 | 09:21 AM
Timing will bounce around on an EFI engine.
underpsi68 is offline
Old 07-08-2017 | 09:32 AM
I was wondering. I don't work on cars or boats much as I've gotten a tad older. I was wondering if that might have been the case.
Old 07-08-2017 | 01:27 PM
Give it very slight throttle. If it runs fine at 1000 rpms and then dies when you go to idle, its the IAC.
Griff is offline
Old 07-08-2017 | 06:39 PM
Thanks Griff. Marina wasn't sure. So I'll run with the IAC, an see what happens next weekend.
Old 07-09-2017 | 08:42 AM
Mentalpause's Avatar
+1. Been there before.
Mentalpause is offline
Old 08-07-2017 | 04:53 PM
BUP
Not saying never but GM IAC rarely a problem. This is not the Ford style IAC used on ECM / PCM 555. But not saying never - Have the techs look into clear flood mode and that starting procedure. What is your rpm idle fully warmed up engine ?
Also they can OHM test the IAC within OHM range to see if it bad or not along with other sensors
Do you have fuel at the fuel rail after engine stalled ? DO the fuel injectors fire right after the stall ? Will they flow fuel upon restart ??
Did any one spark check the ignition properly and safely ???
fuel pressure is ? Vaccum hg testing the fuel system --- Run engine on a portable gas tank to see what happens .
That's a lot of parts changing man - marine techs have done all those changes ? or ?
Are they Merc trained ?
BUP is offline
Old 08-07-2017 | 05:22 PM
Think Griff's got you on the issue
AllDodge is offline
