Blower with Carb questions >
Old 07-09-2017 | 12:09 PM
Default Blower with Carb questions
502 with 10-71 blower/intercooler twin 750 carbs on top. Jet size is 74/84 with 4.5 Power Valve. Set timing on stand, installed in boat and when in gear at 2800-3200 engines will flood out. PV is not boost referenced. 7 psi at the regulator. A1000's feeding aeronotive regulators....I'm no carb expert and am thinking my PV are set to low? Any help is appreciated
TruxtonFox is offline
Old 07-09-2017 | 06:58 PM
GPM
Just curious, and have no clue, would that motor ever see vacuum with a Roots style blower
GPM is offline
Old 07-09-2017 | 07:26 PM
I'm not sure, my next step is to hookup vacuum gauges above and below the blower to get an adequate reasing
Old 07-09-2017 | 07:49 PM
F-2 Speedy's Avatar
Tell us more about the 502
F-2 Speedy is offline
Old 07-09-2017 | 08:00 PM
Nothing fancy, worked 088 heads, stock cam, dry tails
Old 07-09-2017 | 08:02 PM
'05 Concept SF23
Get hold of Dean Nickerson in Bristol PA. He is a blower carb guru
f311fr1 is offline
Old 07-09-2017 | 08:27 PM
He's on my call list for tomorrow
Old 07-10-2017 | 03:07 PM
explain flooding out ?
ezstriper is offline
Old 07-10-2017 | 03:43 PM
F-2 Speedy's Avatar
Thats a big blower for 502 displacement, what exhaust are you running
Old 07-10-2017 | 10:31 PM
with non boost referenced carbs i use a 9.5 or 10.5 power valve.how far out are you idle mixture screws?
mike tkach is offline
