Some parts i need to part with >
Old 07-10-2017 | 09:34 PM
Wally's Avatar
Were doomed!
Default Some parts i need to part with
I can finally see the light at the end of the tunnel for my project but still need to liquidate some stuff to Finnish my boat off. So if anyone has any interest in this stuff let me know...it gets posted on eBay come this weekend. Thanks
Gen IV 8qt oil pan - $50
GM "395" cam with roller lifters --$100
Dominator carb style (i think) flame arrestor/filter - $40 needs a little elbow grease to shine...i polished one section pictured in 5 min with Brasso
Mercruiser Thunderbolt IV V6 ignition module (older style) --$100
4 blade Left Hand aluminum prop...not sure if ever been used but it does have one small ding on each prop end...would not affect performance i think, comes with the flo-torque hub 14x20P LH --$40
Inner transome plates for either Bravo or Alpha --$25 for the white one --$35 for the blue one with the steering on it
BBC Alt brackets one has part# 474871 but both are the same --$35ea SOLD
Stock BBC oval port intake off a 1991 bravo 7.4 --$35
Stock BBC Aluminum Rectangle port intake -- $100
10 pin engine harness with breaker and solenoid and throttle bracket..i think it came off a 5.0 efi motor but not sure. --$50?? SOLD
New Brazil Valve for adding had steering rams to stock steering--$50
BBC or SBC motor mounts and pedestals--- $40 SOLD
Alpha Outdrive lock new in package. ---$40
I also have two fully rebuilt seawater pumps.
First one is the older style that takes a bolt on pulley, Comes with mounting brackets, Sandblasted/painted and All new seals and new bearings. The impeller is not brand brand new but is new..just sat around for a while...i was keeping it for a spare but don't need two of them! -- $125 SOLD
Second one is the newer style with the full pump boss on it...this one has the v-groove pulley on it...it too has been sandblasted and painted...i drilled and tapped a drain plug for easier maintenance too. I upgraded the bearing to full contact seals and removed the inner seals for the oil bath these use....so you know have double seals on each end of the pump for added protection. Comes with brackets and the tensioner pulley bracket...needs a new tensioner pulley though...$150 for this one SOLD
-Wally
Wally is offline
Old 07-10-2017 | 09:39 PM
Wally's Avatar
Were doomed!
prop
Attached Thumbnails Some parts i need to part with-img_4028.jpg   Some parts i need to part with-img_4029.jpg   Some parts i need to part with-img_4030.jpg
-Wally
Wally is offline
Old 07-10-2017 | 09:40 PM
Wally's Avatar
Were doomed!
oil pan
Attached Thumbnails Some parts i need to part with-img_4083.jpg   Some parts i need to part with-img_4084.jpg
-Wally
Wally is offline
Old 07-10-2017 | 09:41 PM
Wally's Avatar
Were doomed!
"395" cam
Attached Thumbnails Some parts i need to part with-img_4069.jpg   Some parts i need to part with-img_4079.jpg
-Wally
Wally is offline
Old 07-10-2017 | 09:42 PM
Wally's Avatar
Were doomed!
v6 module
-Wally
Wally is offline
Old 07-10-2017 | 09:44 PM
Wally's Avatar
Were doomed!
sea water pump with fuel pump boss SOLD
Attached Thumbnails Some parts i need to part with-img_4017.jpg   Some parts i need to part with-img_4018.jpg   Some parts i need to part with-img_4019.jpg
Some parts i need to part with-img_4020.jpg   Some parts i need to part with-img_4021.jpg   Some parts i need to part with-img_4022.jpg
-Wally
Wally is offline
Old 07-10-2017 | 09:45 PM
Wally's Avatar
Were doomed!
seawater pump without fuel pump boss SOLD
-Wally
Wally is offline
Old 07-10-2017 | 09:46 PM
Wally's Avatar
Were doomed!
motor mounts SOLD
-Wally
Wally is offline
Old 07-10-2017 | 09:49 PM
Wally's Avatar
Were doomed!
Brazil Valve
Attached Thumbnails Some parts i need to part with-img_4104.jpg   Some parts i need to part with-img_4103.jpg   Some parts i need to part with-img_4105.jpg
-Wally
Wally is offline
Old 07-10-2017 | 09:51 PM
Wally's Avatar
Were doomed!
flame arrestor 5" throat opening
Attached Thumbnails Some parts i need to part with-img_4085.jpg   Some parts i need to part with-img_4086.jpg   Some parts i need to part with-img_4087.jpg
-Wally
Wally is offline
