Need to pull motors on trailer in driveway.
I've got to pull my engines for the winter. The INSTIGATOR is in my driveway in New Baltimore, MI on it's trailer. I want to pull the engines to rebuild them over the winter. Does anyone have/know of a cherrypicker or something to help? It's got to reach up about 10'. Thanks!
You might find an "A" frame hoist to do that but, it would be easier to rent a fork lift for the day....chain from the forks.....easy lift, carry to the truck, loak in the bed.... go get the send one...
ive tried to pull my motor with a big cherry picker and i came up about 3" to short, pain in the a$$. formula's got the right idea i ended ip using a buddy's bobcat but you can rent em cheap. good luck
if your only 3" short let eth air out of your trailer tires or remove thema altogether and block your trailer. That will lower the engine 6 inches or so.
Pardon me, while I whip this out!
I bought a cherry picker out of mc master carr and came up the three inches short (as usual my wife says
). I then designed an extension that fits on the end of the ram, between it and the boom. It was made on a lathe out of a 5" dia piece of 4140. I made it at work, but any machine shop could make the part for cheap. If you have autocad, and if I can locate the drawing, I could email it to you. Works great for me.
BT
). I then designed an extension that fits on the end of the ram, between it and the boom. It was made on a lathe out of a 5" dia piece of 4140. I made it at work, but any machine shop could make the part for cheap. If you have autocad, and if I can locate the drawing, I could email it to you. Works great for me.BT
Best bet is to get the motors ready, loose and all unbolted. Get a tow truck with a long boom and pull them both at the same time. Should be no more than a half hour and cost about 100 bucks-50 if it's a cash deal
Unless you have a buddy with a boom truck, then it's all in the cooler
