260 Prop Question >
260 Prop Question
260 Prop Question
Old 07-11-2017 | 01:03 PM
Default 260 Prop Question
I bought my 260 Velocity with a BBlades 26P Bravo 1. Just bought a Merc Revolution 4 Blade 25P to try out. Anybody have any useage input on the Revolution prop ?
90profx is offline
Old 07-12-2017 | 09:33 AM
How were you RPM wise with the B1? The 25 Rev 4. Is a lot more prop than a 26B1. I'd like to see how you make out. When are you trying it. Post some back to back results if you can.
class6 is offline
Old 07-12-2017 | 09:54 AM
When it's the wife and I out on the water, I'll hit the limiter with the BBlades Bravo 1/26P. I agree, the Rev 4 diameter is rather large but I kinda figured at 1" less pitch it may be the ticket. As for any water testing........., it's gonna be awhile, our waters are full of debris from the constant heavy rains we've gotten week after week. Just when it starts to clear another heavy storm rolls in. I've already bent one blade on the BBlades 26P and I'm not taking any more risks on another prop or drive, it's ugly around here. Just came back from Lake Cumberland KY where it's beautiful, shame its so far away from me. I'll post back once I try it out.
90profx is offline
Old 07-12-2017 | 02:11 PM
What engine do you have ? I just ordered a Cutting Edge 28 to try on my 290sc with a 496 mag HO...
Cutting Edge Propellers | Cutting Edge Labbed Props & Propeller Repair
Boatally Insane is offline
Old 07-12-2017 | 02:23 PM
Mine has a 496 MAG, stock except for K&N Flame Arrester and Dry Exhaust.
90profx is offline
Old 07-12-2017 | 07:45 PM
I had a 25p Rev 4 on a 24 ft outlaw 502 mag. It was slow out of the hole and ran at 4600rpm. It's a big diameter prop. I switched to a 25p 3 blade mirage. Way better with the mirage. Faster and mix better out of the hole
veloc410 is offline
Old 07-13-2017 | 04:32 AM
Thanks for the info. I realize it'll be slow out of the hole more so because it's a pad hull but I've got to give it a try.
90profx is offline
Old 07-15-2017 | 09:35 PM
If you have a high drive hieght it might work good
veloc410 is offline
Old 07-16-2017 | 06:12 AM
Actually never really measured the "X" dimension for drive height. I'm sure it's standard issue as the boat was set up with a lower HP 496 MAG motor, nothing exotic............. But I agree the big diameter prop would favor a higher "X" dimension.
90profx is offline
Old 08-21-2017 | 07:50 AM
Update on the 25P (stock) Revolution 4: I'm big time impressed with this prop. Hole shot with trim 1/2 down from full, 80 gals of fuel, coolers and skis, inflatables, towels and misc. stuff (wife 121 lbs, me at 175 lbs, 5 grandkids at 475 total of the 5), 3 seconds and it's on plane, motor doesn't lug like the Bravo did and it was 96 degrees w/82% humidity (boating in a sauna). As for top speed, can't give you that yet as I had all the grand kids in the boat yesterday, but aside from that, I'm love'n this prop so far, it's a 25P (big as they go), but if all works out, it'll be off to the prop shop for some extra cupping and/or pitch as needed. Even though it's a pad boat, I was able to keep the bow much higher than normal while cruising at 40-50 MPH, and it felt very good all around. I did notice a little blowout (big dia. prop) at time of hole shot but it's easy to control by just pulling back a little as time to plane is so fast anyway. In a nut shell, if you can borrow one to try...........DO IT.
90profx is offline
