Go Back  Offshoreonly.com > Owners Forum > Donzi
Donzi 22 porpoising >
Donzi 22 porpoising
Donzi 22 porpoising
Old 07-13-2017, 02:01 PM
Pdm
Default Donzi 22 porpoising
has anyone solved the porpoising of a 22 classic with a 496? If so, how? Thanks
Pdm is offline
Old 07-13-2017, 04:36 PM
http://www.offshoreonly.com/forums/d...ssic-help.html
Ken
minxguy is offline
Old 07-13-2017, 06:29 PM
Throw out everything you know about driving a boat and start over!
thirdchildhood is offline
Old 07-13-2017, 08:18 PM
It cannot be fixed. Sell it, to me. I like porpoising. LOL
Check out the link in post # 2. Lots of good info in there.
350scarab is offline
Old 08-28-2017, 01:28 PM
Glass in a lead block in the bow! good luck!
mruss12 is offline
Old 08-29-2017, 02:18 PM
Tom A.'s Avatar
I had a 22 Classic with a supercharged 454 and it ran 80+ mph. Play with some different props and also weight in the bow of the boat. Also check the bottom for a hook as well.
I don't remember if needed a little bow lift or if it did not want bow lift but it was very sensitive to which prop you used.
Also, as stupid as it sounds, it ran faster with a full load of fuel and a couple people on board than it did empty.
Definitely a drivers boat and yes you can fix it.
Tom A. is offline
Old 08-30-2017, 06:41 AM
Do not put weight in the front. A properly set up 22 Classic likes a light bow and a prop that gives bow lift.
Old 08-30-2017, 10:44 AM
Tom A.'s Avatar
My boat ran best when I had all my safety gear, tools, etc under the deck of the boat. I guess it was closer to the cockpit than the bow under the deck now that I think about it.
Tom A. is offline
