525SC Oil Thermostat change out and oil line routing >
Old 07-14-2017 | 07:03 AM
Jim Diesel's Avatar
"Unregistered Gun"
Default 525SC Oil Thermostat change out and oil line routing
Hey guys, I'm fixing to change the oil thermostats in a set of 525SC's and wanted to know the best way to do this? It looks like I could just un-bolt the oil adapter housing and I should have enough slack to get to the snap ring. Also does anyone have the oil adapter and oil cooler hose connection diagram, I have this diagram but it don't show the connection.
Thanks!!
Attached Thumbnails 525SC Oil Thermostat change out and oil line routing-85199921.png
Jim Diesel is offline
Old 07-14-2017 | 07:09 AM
F-2 Speedy's Avatar
525 SC ?? are these custom built...or do you mean 575 SC
F-2 Speedy is offline
Old 07-14-2017 | 07:19 AM
Knot 4 Me's Avatar
525SC's were the Merc 454's with a 177 blower I believe..
Knot 4 Me is offline
Old 07-14-2017 | 07:34 AM
F-2 Speedy's Avatar
I see....never seen one
Old 07-14-2017 | 08:54 AM
Jim Diesel's Avatar
"Unregistered Gun"
F-2, They're Mercury Racing 525SC which is a 454 with a Wieland 177 blower making 5-6 psi boost.
Attached Thumbnails 525SC Oil Thermostat change out and oil line routing-img_7682.jpg   525SC Oil Thermostat change out and oil line routing-image1.jpg
Old 07-14-2017 | 08:58 AM
F-2 Speedy's Avatar
if your just changing the thermo, just do as you say to get to the snap ring..........whats the reason for this,
Old 07-14-2017 | 09:07 AM
Jim Diesel's Avatar
"Unregistered Gun"
Its been running higher then normal oil temps, I say the oil T-stats are probably original and I think there stuck or partially stuck and not recirculating the cooled oil from the cooler into the system.
