8.1 496 double roller timing set
As to what the title says where is a place to source a double roller timing set for the 8.1. Also when buying a set what version is it going to be since there were 3 different versions and only the latest has cam sensors available still.
Not sure you can make that work with the cam sensors and how tight everything is. You can find the early black cam sensors if you search on eBay and such. I had two spares for my 2003 496s which I gave to the new owner. I also have an extra black cam sensor (same piece) for my 2003 Silverado 2500HD with the 8.1L as well.
OE replacement you can get thru GM.
Googled for aftermarket roller and found this, read the review as it may be helpful:
https://www.summitracing.com/parts/c...77-1/overview/
Also, not sure which cam sensor and ti,img chain cover type works with it. Again. I googled that. do your homework.
http://www.raylarengineering.com/vor...aft-gears.html
If you are keeping your current crank and cam sprockets and just want to upgrade the timing chain, then a standard aftermarket big block chevrolet 66 tooth type true double roller timing chain will work just fine. Cloyes, etc.
