need help finding starter solenoid. >
Old 07-16-2017 | 06:17 PM
Default need help finding starter solenoid.
does anyone know where i can get one of these? The main stud stripped so i cant tighten the cable down. The ones ive found online have mounting screws on the end. Mine has 3 that screw into the side.
No part # in it anywhere. Mark iv 502.
Attached Thumbnails need help finding starter solenoid.-img_2987.jpg   need help finding starter solenoid.-img_2986.jpg
cabin fever is offline
Old 07-16-2017 | 08:50 PM
Just 1 more bite in the ass...is there any good thread at end of stud? You could shim it with washers or a nut under the nut. Otherwise you are probably looking at new starter.
dereknkathy is offline
Old 07-16-2017 | 10:12 PM
Yea its the never ending nightmare
unfortunatley no threads at the end. Shiming it would only make it worse
if its better to get a starter, wheres the best place to get one?
Old 07-16-2017 | 10:24 PM
try a starter rebuild shop, maybe they can just change out the stud gd luck
I'CE is offline
Old 07-17-2017 | 06:18 AM
In the old days you take the cap off and replace the studs. This cap is installed by pressing (in a press) the edges of solenoid body over the cap. Designed to be non-repairable. And I have seen a pic,of a solenoid like this only once. You want in the water now auto ports store. 78 chebby pick up with 454 starter. 30 to 50 bucks. Or marine place. 100 to 300.
Old 07-17-2017 | 06:23 AM
SB
You need to have your hands / forearm calibrated. This the 3rd or 4th thing stripped ? Doh !
SB is offline
Old 07-17-2017 | 08:41 AM
Lol. Yea i havnt had to much luck lately. This one was on borrowed time to begin with. The threads basically just unwinded from the stud.
Ill probably just bite the bullet and replace the starter.
Old 07-17-2017 | 08:42 AM
http://dbelectrical.com/
blaquebaja is offline
Old 07-17-2017 | 08:59 AM
Another thought. That stuff is pretty soft. Get something like a 5/16 18 thread die and you might be able to cut a new smaller thread on it. Let's face it you're not going to make it any worse.
Old 07-17-2017 | 10:42 AM
Geez. Never had this much trouble finding a starter or solenoid before. I cant find anything that looks like mine. Is cause i have a bowtie block?
im gonna try to tap new threads on it tonight but if for what ever reason it wont work id like to find a replacement. Ill pull the starter off tonight and look for a part # if i have to.
