525 water pressure sensor >
Old 07-19-2017 | 10:39 AM
Default 525 water pressure sensor
Want to buy, borrow, or ? even if it's used a water pressure sensor for 525 EFI. Some one have a spare? Mine doing some crazy readings, It's probably faulty, but before I buy a new one I want to check it out. THX.
PARADOX is offline
Old 07-19-2017 | 11:07 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Have you pulled your existing one out, and made sure you don't have debris jammed in it?
Sydwayz is offline
Old 07-19-2017 | 01:20 PM
It's out, clean, flushed, still shows 43+at idle. Either it's busted, or I have a restriction, but in idle even a restriction shouldn't show this high. Besides, I flushed and back flushed all hoses. For a long time I had a gremlin of low WP, now it's high. I assume it's the sensor.
PARADOX is offline
