Question convert 502 efi to carb. >
Old 07-19-2017 | 11:34 AM
Default Question convert 502 efi to carb.
i have twin gen 6 502 efi motors. I've had nothing but problems with them. Port motor has 50 hours and starboard has 1 hour on it, both completely stock engines. Looking for recommendation on carbs to get. Eliminating the fuel injection
Dmsroxstar is offline
Old 07-19-2017 | 11:43 AM
Quickfuel 850m and Victor Jr. manifolds should do the trick.
Baja Rooster is offline
Old 07-19-2017 | 02:09 PM
Agreed. Unless you are a 3500 to 4500 rpm kind of guy. Then you want dual plane intakes. The stock Mercruiser one with the bronze water passage across the front is a very good intake. Now, your ignition system. You have delco EST. You need delco voyager modules or you will have no advance. Or get 2 large cap HEI distributors and get the blank-off plates to eliminate the vac advance cans.
dereknkathy is offline
Old 07-19-2017 | 02:21 PM
F-2 Speedy's Avatar
I've never seen a 502 mag mpi engines that cant be fixed, what are they doing wrong and who's been working on them, changing to carb doesn't guarantee trouble free boating
F-2 Speedy is offline
Old 07-19-2017 | 02:26 PM
The DUI distributor has worked well for me. Just plug in the tach lead and one 12g power wire and you're up and running.
Old 07-19-2017 | 02:57 PM
The DUI is a 400 dollar large cap HEI.
Old 07-19-2017 | 05:57 PM
Steve H's Avatar
artselectricinc.com
The existing distributors will work fine.
Steve H is offline
Old 07-19-2017 | 06:31 PM
Craney's Avatar
I have a band new HEI distributor for a $100.00
Craney is offline
Old 07-19-2017 | 09:20 PM
SB
He can use his current EFI distributor, without computer control of course. The module inside should have a short advance curve built in, if not, the appropiate GM module is about $70.00 . If you want to go with a killer ignition with programmable advance curves, rev limit, idle stabilization, and etc, you can use the same distributor, but bypass the module and add the Daytona Sensors Marine Ignition Box and coil.
SB is offline
Old 07-19-2017 | 09:25 PM
SB
He can use his current EFI distributor, without computer control of course. The module inside should have a short and real quick advance curve built in, if not the appropiate GM module D1965A is about $70.00 . Advance is 22* and super quick. If you want to go with a killer ignition with programmable advance curves, rev limit, idle stabilization, and etc, you can use the same distributor, but bypass the module and add the Daytona Sensors Marine Ignition Box and coil.
SB is offline
