1981 330 TRS will not idle or run below 1,250 RPM. >
Old 07-19-2017 | 10:00 PM
Default 1981 330 TRS will not idle or run below 1,250 RPM.
Changed a few things wires, coil, headers, plugs, and electric fuel pump.
Swapped carbs no change.
Runs good at 1,250 and above under that it dies. If I pull it back to idle it quit if I slowly pull it back to idle it stumbles and dies.
1981Scarab is offline
Old 07-19-2017 | 10:05 PM
jeff32's Avatar
No connection with drives imo
both were ok lets say last year? It started for both at the same time?
need more info to try to help you!
jeff32 is offline
Old 07-19-2017 | 10:28 PM
SB
Ck fuel psi and charging system at idle.
SB is offline
Old 07-20-2017 | 04:49 AM
Full Force's Avatar
Check or adjust points? those need replaced at tune up time also....
Full Force is offline
Old 07-20-2017 | 05:20 AM
Swap carb no change. I assume 2 engines? Carb idles on other engine, both carbs won't idle on this engine? Bad vacuum leak.
dereknkathy is offline
Old 07-21-2017 | 03:53 AM
Yes twin engines.
Old 07-21-2017 | 06:31 AM
F-2 Speedy's Avatar
have you double checked the firing order after changing the wires, vacuum leak ? what's the fuel pressure
F-2 Speedy is offline
Old 07-21-2017 | 07:05 AM
Could be trash in your carbs. I have had one of boats not idle and die like that but would run ok with more rpm. Ended up being trash in the jets.
cdail28590 is offline
Old 07-21-2017 | 08:21 AM
I think both carbs run good on the other engine, and both won't idle on this engine. Makes me think vacuum leak cuz engine is ok under power. Check if it has pcv and broken hose. Otherwise intake manifold gasket.
