Oil Temp Sender Install
Old 07-25-2017 | 04:21 PM
Default Oil Temp Sender Install
Picked up a AN10 with 1/8 NPT fitting in an attempt to install a second oil temp sender after the cooler. The sender (VOD 300 degree) will fit but the sender is to long, and even if it was a bit shorter it would restrict the oil flow, taking up almost half the diameter. Current sender is before the cooler in the filter housing, and temps will go above 260 degrees at 4k rpms. Like to find out how much the cooler is cooling the oil but still think the 525 cooler is not enough. There is no thermostat in line
AllDodge is offline
