New owner with 525SC questions >
Old 07-28-2017 | 09:46 AM
Default New owner with 525SC questions
New Formula owner with Gen VI 525SC questions as follows:
1. I want to add water pressure gauges, is there a preferred location for a sender based on your experience?
2. Is there anything "marine special" about the 1050 Dominators (other than jetting)? I think these are as-shipped by the factory but I intend to baseline them to be sure.
3. I have Blower Shop 250s. Other than periodic oil changes, are those of you who own these returning them for the prescribed periodic service or maintaining them in a different way?
4. This boat does not have fuel pressure gauges. Are they needed in this configuration?
Thanks.
Thunderous is offline
Old 07-28-2017 | 12:55 PM
the carbs are special as they run 2 power valves and staggered jetting in most cases, blowers have their own small amount of oil
ezstriper is offline
Old 07-28-2017 | 04:20 PM
The stock jetting is # 98's in all holes with 6.5 PV's on both sides. They are marine carbs with j tubes and different shaft seals.
My water psi guage connection on my 525SC was in the block drain hole. It would get clogged pretty easily there.
Fuel psi is never a bad thing to have, but i did not have one on my 525SC. Change the lube in the blower and sea pump/fuel pump every 50 hrs or so.
Griff is offline
