Scarab 377 Staggered >
Old 07-31-2017 | 08:56 PM
Default Scarab 377 Staggered
I'm looking for a 1979-1984 Wellcraft Scarab 377 with the staggered engine layout as a project boat. Must have all rigging and power. Must not be bottom painted.
Target price: under $10,000 depending on condition
Are any of these hiding around?
NautiSouth is offline
Old 07-31-2017 | 11:08 PM
hblair's Avatar
They pop up occasionally on he powrboat swap shop on Facebook.
hblair is offline
Old 08-01-2017 | 04:44 AM
Thanks for the tip-I just requested to join that group.
Old 08-01-2017 | 07:06 AM
Sick Stinger's Avatar
Brotherhood #1
One on Craigslist I saw last night
Sick Stinger is offline
Old 08-01-2017 | 07:43 AM
https://detroit.craigslist.org/wyn/b...213976675.html
a little above your budget, but it is a staggered 377...
offshore312 is offline
Old 08-01-2017 | 07:51 AM
Yes, I've seen this one - the bottom paint makes me reluctant to talk seriously. While I've never removed bottom paint, I can't imagine it would be a pleasant job, nor would be potentially re-spraying and sanding fair the entire bottom. I've done some gelcoat work (transom and some interior pieces of my current boat) and that was a big enough job on its own.
Has anyone tackled removing bottom paint and have a story to tell?
Old 08-01-2017 | 07:57 AM
did it on my Stinger, while it's not the easiest job it's not the worst either...
Old 08-01-2017 | 08:07 AM
What do you consider to be the worst job, so I'll have a frame of reference?
Old 08-01-2017 | 11:54 AM
phughes69's Avatar
I took the bottom paint off the bow area of my Formula 242LS. Why someone would paint the whole hull black is beyond me. I used Aqua Strip. It worked very well. I did it about 3 times. It got it down to the original gelcoat. The only downside was the boat had black bottom paint over red bottom paint over the white gelcoat. When I got the gelcoat cleaned up the red bottom paint was stuck in all the sanding grooves from where they rough sanded the bottom to prep it for paint. I think they sanded it with 20 grit sandpaper, the grooves were so deep. Ive heard that bottom paint only knocks off 3-4 MPH, so does the cost and effort to remove bottom paint justify the speed gains on an old staggered 377 Scarab, probably not. It just creates a negotiating point to get the boat cheaper.
phughes69 is offline
Old 08-01-2017 | 01:59 PM
I know of one in the Tri-City area. I'm not sure of the guys story but he has been out of contact for a while and the boat has been sitting all summer, he may be willing to sell. It is definitely a 377 Scarab but can't say for sure if it's staggered or not.
TPro587 is offline
