Bmax seeping oil slightly, what to do?
I have a Bmax behind a 911 HP motor. Where it mates to the transom assembly it is seeping oil ever so slightly. On both sides it's just a little shiny. When you run your finger on it, it is slimy so I know it's drive oil. My questions are.....what are the chances water is getting in? Since oil floats on water can I pull the plug to make sure no water comes out and then top off the fluid again(obviously from the bottom up)? The drive does have all new seals since I put the motor and drive on and have only about 1 hour of run time. When installing the drive we ran into problems and had to remove it and install it again. Basically I am trying to avoid ordering seals and fluid and having to spend the better part of a day doing this again. It's early august and I have been out on the water 1 time after spending 15k on this boat. I don't really have another dime for gas let alone pulling this drive again. So what do you guys think? What are the chances of it letting water in?
So, you think it was a seal that was just replaced ? Why not have the place that did this fix it ? Or atleast check to see if o-ring where oil passage is from drive to transom assembly ?
And btw: I see more people lose their shirts on stock power stuff....but they don't post here/
I'm not really sure. It's coming from where the drive meets the transom assembly. It's on both sides. It's very slight. Just a little slime on both sides and hardly noticeable. It's on both sides and at the very top so I'm not to sure. Maybe both too bolts? I think it's too high to be from the reservoir.
Oh oh and who did the work????.....yours truly! I am dreading lifting this thing again, still waiting for my nuts to come back out!!
