pitch change >
pitch change
pitch change
Old 08-10-2017 | 07:28 AM
Default pitch change
Hi,
Will Maximus ST prop keep initially efficiency if professional change original pitch from 30" to 28", or if he change original 26" pitch to 28"?
Is it better to buy 28" prop?
Prop is totaly surfaced, shaft is in line with transom.
plavutka is offline
Old 08-11-2017 | 11:51 AM
General rule is pitch can only be changed by 1 inch.
IMO, better off to get a new 28.
Griff is offline
Old 08-25-2017 | 11:17 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Originally Posted by plavutka
Hi,
First off, short tub is just the stock prop with the diff cut down. It isn't anything special or a new casting.
Best case scenario is to buy the 28.
If you are going to modify one of the others, we would base some of it on the current efficacy or lack there of. Slip %.
We do prefer to only adjust 1 inch of pitch . Blade roots can not be changed.
Brett
[email protected]
bbladesprops is offline
