Bravo Drive - No Forward
Just winterized the Fountain and decided to take my family for a ride in the deckboat. Rinker Flotilla with 5.7/Bravo III. Going down the lake at 3000 rpm and the thing revs up and stops going forward. Dink around with it and find that it will go in reverse and back up but does not even begin to go in forward. Raise the lower unit and see that the props are turning (forward) but when you give it the gas it just revs up the engine. Shut it down and grap the props and it acts like it is in gear. Had to tow it 8 miles home, put it on the lift and now it does not even turn the props in forward (engine running). Has any one ever replaced the clutch assembly in a Bravo drive? What about the upper gear set? Looks like it is fairly simple. What else could be causing this to happen. Is it possible that the shifter assembly has broken?.
No clunking or grinding noises, just does not go in gear. My first mate is ticked off, wanted to do some fall foilage cruising this fall.
Any help appreciated.
Thanks,
Helmwurst
Thanks,
Helmwurst
You may want to check the drive coupler before tearing down your bravo. Just look over the engine, when idling the drive input shaft should be turning always..... I hope thats your problem, easy fix & inexpensive.
I have had two similar experiances. Once it was the shift linkage back at the engine that was out of adjustment and once it was the cladding on the shift wire from the engine down to the drive that was broken between the transom assembly and the drive.Worth a look
Me too on the out of adjustment shift cable. And then there was once when the mechanic used an incompatible shift fork with the wrong clutch..........
The part that is wierd is that it happened at speed. When producing thrust, the torque of the upper gear drives the clutch into it. A maladjusted cable shouldn't cause this I wouldn't think.
