08' Fountain 496HO Low RPM 's
Hopefully someone can help or point in right direction. I have an 2008 Fountain 35 Lightning with staggered 496HO. My port engine gets 4750RPM and my Starboard engine is only getting 4450 RPM. I'm only hitting low to mid 70's. I have Maximus 5 bladed props with 31P that were just balanced. Any insight will help.
Scan the engines and look for guardian mode faults - then look at available power in the scan --- I bet its showing like 90 % or 89 % or maybe even less for available power.
Balance props and repaired on top of ?? Bad rebuilt ? Or some form of prop issues after prop work ??? any current prop damage,
or low compression of that engine.
bad coils / and or spark related issue - possible spark plugs and or wires
scan tool is needed for sure
If you are DFW Texas let me know, .I have everything
Its an 08' fountain with 496HO Staggered, XR drives, shorty sport master lowers. 1.35 gear ratio. 5 bladed Maximus props, 31P. Boat came from factory with this set up. Boat ran with this set up 5100 rpms @ 83MPH.
Everything that BUP said is correct.
I have personally seen Crankshaft Position Sensors on 496HOs go bad withOUT showing a code or Guardian mode; that cause an engine to be down on RPMs slightly.
BUP helped me through this a few years ago.
