454 Oil cooler separated
Old 08-14-2017 | 10:34 PM
Default 454 Oil cooler separated
My oil cooler separated the other day on my Gen IV 454. The part the water line connect to just blew off. Oil still looks good so I was thinking about just having someone weld it instead of spending $500 on a new one. Thoughts?
FuelinAround is offline
Old 08-15-2017 | 02:42 AM
radiator shop can usually put them back together.. if not, plenty of upgraded ones out there for less than an oem unit.
downforce137 is offline
Old 08-15-2017 | 04:42 AM
Ayuh,.... They're just soldered together,....
I'm guessin' yer's froze at some point, causin' the problem,....
Bondo is offline
Old 08-15-2017 | 06:33 AM
You can do it yourself with a propane torch, some flux and solder. Copper solders up good. Scrounge around and try to find real lead solder. I have one popped in half from freezing.
dereknkathy is offline
Old 08-15-2017 | 07:55 AM
Boat has been stored in a heated garage for 10 years so I don't think it froze. I didn't realize these were just soldered together. I have a randiator and welding shop next to work. I will probably drop it there today and see how it holds. Thanks guys! Any recommendations on after market replacements if I went that route? I assume Sierra or someone has one
Old 08-15-2017 | 07:57 AM
Mercruiser Coolers
Go here and buy new. High quality stuff and much less $$$.
sonicss42 is offline
Old 08-18-2017 | 03:53 PM
Cpperformance has new ones at good prices 229 for one up to 450 hp with 3/4 connections
sparky24 is offline
Old 09-01-2017 | 09:49 AM
rich allen's Avatar
This happened to me a few years ago. I was idling through a channel and by the time I realized what happened I was taking on serious water. The end cap just popped off. I did re-solder, but as a precaution, I safety wired the two end caps to each other. In that way, if it ever happened again, at least the caps would not pop completely off, making the leak manageable and ability to run motor until I got back to shore.
rich allen is offline
Old 09-01-2017 | 09:09 PM
masi242's Avatar
i did replace mine a few years back from Mr Cool i was a perfect fit,
masi242 is offline
Old 09-01-2017 | 09:18 PM
Originally Posted by sonicss42
Mercruiser Coolers
I bought an oil cooler from above for my 496. No where near the quality of the Mercruiser. Had thin stamped end caps compared to the Mercruiser thick cast caps. I sent it back and spent the extra money for OEM.
underpsi68 is offline
