Timing mark on 502 on  balancer >
Old 08-15-2017 | 04:07 PM
Default Timing mark on 502 on balancer
there is no timing tape just a mark does anyone know how much timing that gives you
dspad is offline
Old 08-15-2017 | 06:18 PM
thats suppose to be tdc.
sutphen 30 is offline
Old 08-15-2017 | 06:59 PM
Not knowing which 502 but figuring it should be 8 BTDC
AllDodge is offline
Old 08-15-2017 | 07:27 PM
Interesting, my Gen VI 502 engines have numbers on balancers.
1BIGJIM is offline
Old 08-15-2017 | 07:37 PM
Gen 6 2000 502 mag mpi
redid the now a 509 with a carb
dspad is offline
Old 08-15-2017 | 07:48 PM
Using a msd setup with box 📦
dspad is offline
Old 08-15-2017 | 09:21 PM
the line on the balancer is tdc when lined up with the timing tang,you need a timing lite with advance knob to check actuial timing.
mike tkach is offline
Old 08-16-2017 | 07:25 AM
Either advance light or timing tape (If the marks have not been painted over)
JEGS Performance Products 40725: Timing Tape for Pontiac with 5.25" Balancer | JEGS
AllDodge is offline
Old 08-16-2017 | 05:33 PM
BUP
you can buy timing tape. Also you have to buy the correct timing tape that matches the size of your harmonic balancer
BUP is offline
Old 11-22-2025 | 04:09 PM
The mark on the balancer is ( top dead center ) 0.00 degrees
GENECYCLEBOY is offline
