Carb leans forward when mounted on intake... >
Old 08-17-2017 | 11:21 PM
Default Carb leans forward when mounted on intake...
I haven't figured out the exact angle yet, but my engine sits pretty level in my boat, when floating. the weiand team g intake i have puts the carb leaning forward. I know everyone sells a wedged spacer to correct this, but is it something i really should worry about? I'd say its leaning forward less than 10 degrees, but usually they are leaning backwards a few degrees i think.
downforce137 is offline
Old 08-18-2017 | 12:19 AM
nothing to worry about,check the carb angle when the boat is sitting in the water.
mike tkach is offline
Old 08-18-2017 | 05:43 AM
its the other way you need to be concerned with
ezstriper is offline
Old 08-18-2017 | 09:14 AM
So you need the angle adaptor plate when carb is pointing uphill-forward at approx the angle the propshaft sticks thru the hull on a shaft boat?
dereknkathy is offline
Old 08-18-2017 | 03:35 PM
The replies have me confused. When the boat sits in the water, the carb leans forward less than 10 degrees. Is this something I should address, or it's fine to run as is?
Old 08-18-2017 | 04:01 PM
Mike says it is ok. So it is ok. I was asking if leaning back was the worry point. My sportfish has angle adapters cuz the engines are sitting at about a 15 degree down angle in the back. The engines have to sit at that angle, or props would stick straight thru transom like an arneson. And the adapters can't be reversed because of the spread bore pattern on bottom side.
Old 08-18-2017 | 05:50 PM
The reason it leans forward is because the intake is usually used in cars. The motors lean backwards. I wouldn't do anything about it. But if putting an angled spacer makes you feel better, do it. It won't effect how the motor runs.
gofastboater is offline
Old 08-18-2017 | 06:10 PM
SB
Angled spacers are typically used in inboards, like dereknkathy's app, because of the large tilt of the motors.
Most intakes are tilted forward a little..some more than others.
When I/O boats are running, most are bow up a little...some bow up more.
SB is offline
Old 08-18-2017 | 09:39 PM
On a boat the fuel is sloshing so hard in those bowls that the carb can barely tell which way is up anyways. Unless you're getting a lean or flooding situation the carb is fairly forgiving, and probably close to level when on plane if it's a V bottom.
Baja Rooster is offline
Old 08-20-2017 | 07:34 AM
Run it>>>
adk61 is offline
