Propping for max HP? >
Old 08-27-2017 | 10:32 PM
Default Propping for max HP?
Looking at the dyno sheets on my Pfaff 700's, I see that they make max HP at 5700rpm. I can only turn the 32B1's that came with the boat 5200rpm. Any chance the boat would pick up any speed with some 30's? That should put me very close to the max HP. I have a LH 30 and can probably borrow a RH to try. Running low 90's now, always looking for more.
They make 677@5200, 700@5700
snapmorgan is offline
Old 08-28-2017 | 06:27 AM
In my experience, the best way to prop comparison test is in calm water with a stop watch. This gives you both top speed and acceleration. Do you have access to a river?
BenPerfected is offline
Old 08-28-2017 | 06:33 AM
Mbam's Avatar
Offshoreonly Advertiser
Hard to say, most likely won't go any faster. But it would sure accelerate harder.
Are your current props labbed? If not that would make a big difference.
Mbam is offline
Old 08-28-2017 | 07:25 AM
depends on how much HP you are giving up at 500 rpm below max HP
ezstriper is offline
Old 08-28-2017 | 08:10 AM
Only talking 25 hp diff. As Marcbam said, same top speed, higher rpm. It would all depend on how well the boat does everything, docking, planing, cruise, fuel burn as to which prop would be preferrable.
dereknkathy is offline
Old 08-28-2017 | 09:32 AM
I have no issues with planing or cruise speed. Current props are not labbed. I probably just need to do some back to back testing and decide from there.
Old 08-28-2017 | 09:33 AM
I am also turning the props out as well. Might try turning them in and see what happens.
Old 08-28-2017 | 05:08 PM
If you aren't making peak HP then you are likely suffering on top speed. In addition acceleration will be improved by propping down from your current set.
The best analogy I can give is look at cars and their top speeds. Many, if not most, pull the highest MPH in something other than top gear (i.e top OD gear). Usually 4th gear for a 5 speed tranny or 5th gear for a 6 spd tranny.
Trash is offline
Old 08-28-2017 | 08:25 PM
I went from labbed 30's to labbed 26's. In the end top speed was the same even though there was close to a 700 rpm difference. Planning was good with both props, the big change was in acceleration. As you can expect the 26's were way better.
You could either lab your current props and gain 200-250 rpms or have them de-pitched and labbed and get exactly where you want to be. If it were me, I would have your 32's made to work with your current set up. Won't be the cheapest, but in the end you will be happier.
endeavour32 is offline
Old 08-29-2017 | 09:24 AM
t500hps's Avatar
21 and 42 footers
You simply need to test. Once we built bigger motors in a 382 I ended up with 4 sets of props. In the end:
28P 15 5/8 maximus cruised the best, 60GPS @ 3,500 with a WOT of 83 @ 5,250
32P Labbed Bravos cruised 58 @ 3,500GPS and WOT of 82 @ 5,350
30P Labbed Bravos cruised 53 @ 3,500GPS and WOT of 87 @5,600
So, what do you want? I wanted cruise speed and stayed with the Maximus.
t500hps is offline
