500 EFI Thermostat Housing Gasket  - Anybody know what the 4 holes are for? >
Old 09-01-2017 | 04:53 PM
GNJ's Avatar
GNJ
Default 500 EFI Thermostat Housing Gasket - Anybody know what the 4 holes are for?
OK I'm trying to figure out what the 4 holes are for in the 500 EFI Mercruiser Thermostat gasket that goes towards the intake side.
Anybody know?
Attached Thumbnails 500 EFI Thermostat Housing Gasket  - Anybody know what the 4 holes are for?-0014738_mercury-marine-part-number-530451.jpeg
GNJ is offline
Old 09-01-2017 | 04:54 PM
SB
Nails !
SB is offline
Old 09-01-2017 | 04:55 PM
SB
Just kidding.
Those small 'rivets'ground the t-stat housing to the intake manifold so that your coolant temp sensors ill work.
So, don't put rtv on them which will keep it from grounding.
SB is offline
Old 09-01-2017 | 04:59 PM
GNJ's Avatar
GNJ
Thanks SB that makes sense - On my 500EFI, the Temp sensors for the gauge and the computer are located in the intake manifold.
GNJ is offline
Old 09-01-2017 | 05:01 PM
SB
Yup, most mercs have one or two in the t-stat housing.
SB is offline
Old 09-01-2017 | 11:02 PM
BUP
crusader uses one brass button hole for a T stat gasket
Mercruiser also uses this same gasket in the pic from the OP post number 1 for carb apps as well --- anyone want to take a guess for a little trivia as to why would Merc use this same T stat gasket for carb apps to ?
BUP is offline
Old 09-02-2017 | 08:45 AM
my first thought is sensors can go in carb thermo housings too, but I have a feeling it is gonna be something goofy...
dereknkathy is offline
Old 09-02-2017 | 09:07 AM
To protect the housing from electrolysis corrsion would be my guess
MichiMike is offline
