99 Donzi Z22BR 383 >
99 Donzi Z22BR 383
99 Donzi Z22BR 383
Old 09-02-2017 | 07:32 PM
Default 99 Donzi Z22BR 383
Anyone know if the Z22BR hull will handle more speed,right now i'm at 54 mph indicated and 48 gps speed.
I have the 350 MPI Mag has 300hp with an alpha Gen 2 with about 100 since a jasper reman. What type of speed will
i see by adding a 383 475hp stroker and a Bravo 1 ?
Donzi Z22 is offline
Old 09-04-2017 | 02:50 PM
Tell us how you plan to get 475hp out of a 383?
1BIGJIM is offline
Old 09-04-2017 | 04:33 PM
Going by what the machine shop says 450 to 475. So is it not likely ? Omaha, lots of kin there.
My family is from a small town called Plainview...
Old 09-04-2017 | 07:23 PM
Well, it certainly can be done, but things like compression ratio, rpm, cam etc required to make that power in a 383 often are not compatible with day to day marine use.
Trash is offline
Old 09-04-2017 | 07:43 PM
You add 150 hp you will add about 10 to 12 mph.
dereknkathy is offline
Old 09-04-2017 | 07:50 PM
How much HP to be used day to day with no issues ?
Old 09-04-2017 | 07:53 PM
Trying to get something reliable and get mid sixes. Is there a rule of thumb for speed ?
Old 09-04-2017 | 08:00 PM
Rookie's Avatar
Yes, the rule of thumb is throw lots and lots of $$$$ at it and it will go faster, maybe...
Rookie is offline
Old 09-04-2017 | 08:19 PM
Rule of thumb is over 1.0 hp per cubic inch is expensive and unreliable. Put a 454 in it. Aluminum heads and it is essentially the same weight as the small block you took out. But you spend 3 to 5k and speedo will say 62 instead of 54. It is a paid for reliable nice setup.
Old 09-04-2017 | 08:26 PM
I just googled the boat..it looks to be less than a 24 degree bottom? and it has a pad? and your seeing 48 mph gps with 300hp thru an alpha?
Before you start building anything, figure out whats wrong first. If its the bottom I saw in the google pik, with 300 hp you should be 10 mph faster.
phragle is offline
