1995 29 BAJA >
1995 29 BAJA
1995 29 BAJA
Old 10-16-2002 | 12:57 AM
737jetmech's Avatar
Question 1995 29 BAJA
I just sold my 23 ' boat and have an eye on a 1995 29 ' BAJA w/7.4's. Are there any problems that are common with this model I should be aware of prior to checking this boat out? I have read about the stringer problems with some of the older (Outlaws) and wonder if anyone has seen this on the ES model?I realize that the 7.4 engines will not set any records on the water, I figure they should be good for about 65 mph. I am just looking for a larger boat that will handle the upper Chesapeake bay water. Seller claims 130 total hours on this boat ! Asking price is $36900. No trailer... Any Information that you Baja guys have on this model would be very helpful... Thanks !!! Bob
737jetmech is offline
Old 10-16-2002 | 05:13 AM
bajadude's Avatar
Welcome to the board and the Baja forum
There was a discussion a little while ago about '29 stringers.
Here's a link to the thread. The stringer discussion is down towards the end.
With 7.4s, 65 (on GPS anyway) may be a little optimistic, but I'm sure someone with a similar setup will chime in and give you some feedback.
bajadude is offline
Old 10-16-2002 | 07:04 AM
Luv-N-It's Avatar
Are you talking about purchasing an Outlaw or the 290 ES Sport?
By the way, welcome to the board. You'll "Luv It"
Luv-N-It is offline
Old 10-16-2002 | 05:08 PM
737jetmech's Avatar
Post 290 ES Sport
The boat I am looking at must be a 290 ES sport , it has the inagraded swim platform. Thanks! Bob
Old 10-16-2002 | 06:41 PM
bajabob
I know what you mean a 29 would be nicer on the Chesapeake. I have a 24 and you can get banged around a little.
Good luck, 130 hrs for a 95 sounds good.
This time of year you should be able to get that price down. The guy won't have to store the boat and all the other stuff that goes along with it.
Old 10-16-2002 | 06:58 PM
Powerboat tested a 290 with 7.4s in the early 90s. Got 72 mph on radar. One thing to remember is that the 290 has 21 deg or deadrise. I've had several dealers tell me that they rode pretty bad in rough water. I'd definatly recomend a test drive. Good luck.
jmeng is offline
Old 10-16-2002 | 07:16 PM
johnnyboatman's Avatar
Default 290os
i own a 94 290 w/454mags shows low 70s on speedo , runs & rides great in rough water , theres a guy in the same dock that has a 93 w/502s and i beat him by 5 boat links across th lake
what colors are on the one your looking at.
johnnyboatman is offline
Old 10-16-2002 | 08:24 PM
737jetmech's Avatar
Post Thanks for the info!!!
I do not know the colors of the boat.Should be looking at it on friday.The photo is in black and white in the add.For all I know this thing could be a peice of $hi&!!!My 23 ' boat was not very good in the bay it too had a 21 degree hull.I had a 7.4 with a 174 B&M power charger on it, but the water was to rough to run any boost.I ran in the mid 70's on better water. Bob
Old 10-16-2002 | 08:39 PM
Default 290os
im thinking of prochargers or the small b&ms blowers i want to see 80plus. iwas thinking of selling mine .its white,two shades of purple. w/tripple axle trailer
Old 10-16-2002 | 09:38 PM
737jetmech's Avatar
Default Prochargers are the way to go!!!
I would go with the prochargers .The 7.4 is limited to 4.5 or 5 psi .Your 454 mags are better suited for supercharging... Bob
roadrep
Baja
7
08-22-2007 01:09 AM
Rebel_Heart
Baja
8
06-29-2007 11:26 AM
Magicfloat
Fountain
0
06-20-2007 12:22 PM
jryan26
Fountain
13
02-18-2006 08:45 PM
liquid asset
6
02-23-2004 07:06 PM
