Eddie Young
Old 09-12-2017 | 11:07 AM
dcb
Default Eddie Young
Called Mr. Young today looking for an aftermarket part number for an IAC for a 525EFI. He took the time to call me back with 2 different part numbers - really appreciate the help. Thanks again ! Dean
dcb is offline
Old 09-12-2017 | 11:55 AM
Eddie is a stand up guy... always takes the time to give great advise!!
adk61 is offline
Old 09-12-2017 | 12:42 PM
It was things like this that made me go to Eddie for my rebuild and will someday go back when needed. Great guy to work with and a great engine builder.
Padraig
Padraig is offline
Old 09-12-2017 | 12:51 PM
So did he give you a different pn than the one that has been posted on OSO in the past? If so, please share.
And Eddie IS a good dude!
ALL_IN! is offline
Old 09-12-2017 | 12:55 PM
dcb
Sorry - NAPA part number 2-29691 and Borg Warner 31069. I believe the application is for a 2000 - 2005 6.8 V10 Ford.
dcb is offline
Old 09-12-2017 | 02:28 PM
I heard it was a Windstar IAC. Either way Ford is cheaper than Mercury... And when somebody saves us a C-note on simple stuff we remember when it is time to spend a bunch of them...
dereknkathy is offline
Old 09-12-2017 | 06:53 PM
SB
Yes #229691 .
Buyers Guide
Ford Truck E Super Duty 1997 - 1998
Ford Truck E350 1 Ton Econoline - Van 1997 - 1998
Ford Truck E350 1 Ton Econoline Club Wagon 1997 - 1999
Ford Truck E350 Super Duty 1 Ton 1999 - 2004
Ford Truck E450 Super Duty 1 1/2 Ton 1999 - 2004
Ford Truck E550 Super Duty 2002 - 2003
Ford Truck Excursion2000 - 2005
Ford Truck F250 Super Duty 3/4 Ton - Pickup 1999 - 2004
Ford Truck F350 Super Duty 1 Ton - Pickup 1999 - 2004
Ford Truck F450 Super Duty 1 1/2 Ton Truck 1999 - 2004
Ford Truck F550 Super Duty 1999 - 2004
SB is offline
Old 09-12-2017 | 07:05 PM
SB
$60.68 Amazon
Motorcraft CX1870 Idle Air Control Motor
by Motorcraft
Link: http://a.co/2j7eTnt
or
$48.78 Amazon
Delphi CV10135 Idle Air Control Valve
by Delphi
Link: http://a.co/jfm5qkV
SB is offline
Old 09-12-2017 | 07:46 PM
BUP
Above post from SB do not use that gasket - you will need to buy the Merc gasket. I had one last year that the owner installed the exact same gasket with his aftermarket IAC on a 525 - Again It was the exact same gasket in the pic above --- To make long story short so here is the short version --- the engine did not like it. period.
Also Merc calls that IAC above Design 1 or gen 1 --- the Design II comes with a pig tail connection - just saying - make sure your connection / connector is good - Had those bad as well.
BUP is offline
Old 09-12-2017 | 07:53 PM
SB
This one right ?
Motorcraft CG763 Gasket
by Motorcraft
Link: http://a.co/hosctTs
SB is offline
