Stellings Trs to Bravo conversion complete with shortie Bravos >
Old 09-13-2017 | 04:41 AM
Full Force's Avatar
Default Stellings Trs to Bravo conversion complete with shortie Bravos
Picked up 89 cigarette cafe racer for myself and found rot, so I am parting it out.. text for pics 440-476-4114
I Have a complete TRS to Bravo1 conversion here ... pretty cool setup since you do not have to do any transom work, and uses a driveshaft to keep engines in current location eliminating transmission.. also helps keep factory center of gravity
You will get Stellings extension boxes
Driveshafts, driveshaft guards, u joints and shaft to crank flange, inner plates (missing some bolts you will have to source them)
You get the top mount starter Trs bell housing (milled for engine plate for starter to engage properly)
Front and rear engine mounts and angle brackets for stringers (missing bolts for mounts)
Outer bravo1 transom assemblies with trim cylinders
Stock Bravo1 uppers with IMCO -2 shortie lowers one needs rebuilt sound a like bearing went bad in lower. Had water in fluid that's all I know I did not run the boat. Both lower prop shafts have light twist to them improved parts value of drives you can upgrade to xr or rebuild stock parts (cheaper)
I am including everything listed and parts are in good used condition, no warranty of any sort... steering and tie bar NOT included selling all that separate.
Asking 12,500.00 for complete conversion as listed picked up 44138 Olmsted Falls Ohio cash talks... pm me
Full Force is offline
