525EFI low power >
525EFI low power
525EFI low power
Old 09-15-2017 | 03:32 AM
Default 525EFI low power
Hi ! I got a Fountain 38 with 2x 525 efi and one it that is said to be rebuilt with piston rings etc. Old original Engine is fine but the other smells gas, feels like 100hp is missing and uses oil and much more gas then the other . Boat only goes 70 mph and should do like 80 at least ?
Anyone that hade the same problem ? I have tried 28p and 30p bravo one props and -2 lower unit.. Almost same speed.
rsmagnum32 is offline
Old 09-15-2017 | 06:39 AM
VoodooRob's Avatar
Engine needs to be scanned to get an idea of problems. If you own Merc Race engines and do not have a Rinda scan tool your throwing darts in the dark.
VoodooRob is offline
Old 09-15-2017 | 07:50 AM
Hi , we have done it no codes exept low water pressure and once we found low fuel pressure , then we ran it with the gauge on the fuel rail and it was okey..
Compression is ok on all 7 cyl, Can one or two bad injectors couse the fault ?
Old 09-15-2017 | 07:55 AM
Dave M's Avatar
Veteran: Navy
Does the scan say that it is at 100% power?
Dave M is offline
Old 09-15-2017 | 08:03 AM
VoodooRob's Avatar
If you have the Rinda or laptop equivalent then you can check for 100% power and do individual cylinder tests. When was IAC unit changed? They are not as much of a problem as 600 and 700 IAC but still can cause problems that do not show up on a scan.
Old 09-15-2017 | 08:08 AM
F-2 Speedy's Avatar
I dont understand this statement ??
F-2 Speedy is offline
Old 09-15-2017 | 08:51 AM
No doubt you need to scan and see what codes you've got but you also need to perform a cylinder leak down test because if you have oil consumption and low power you may have internal damage which at that point you would want to stop using to avoid further damage. Best of luck keep us updated. Sincerely Laz Mesa
MESABALANCING is offline
Old 09-15-2017 | 12:44 PM
BUP
did both engines reach MAX wot rpms ?
Look at MAP readings while scanning, then compare between the 2 engines at same rpms thru out
Fuel pressure readings are ?
Spark plugs look like ? oil fouled, gas fouled or lean or ???
compression test on ALL 8 was ????????
BUP is offline
