94-96 454-502 keihin injector fuel rail >
Old 09-15-2017 | 10:35 AM
Default 94-96 454-502 keihin injector fuel rail
Wanting to purchase just the rail for a early mag efi intake the one that used Keihin injectors, wanting one to send to Eddie Young to make if feed from both ends of the rail. Not wanting to spend a lot on it. 805405T part number
kip4234 is offline
Old 09-15-2017 | 11:35 AM
Team Archer's Avatar
have a bunch of old efi parts. send me a pic if you can Regards Dan 949-646-9778
Team Archer is offline
Old 09-15-2017 | 12:18 PM
I'm in North Texas , have 2 of those .
airjunky is offline
Old 09-15-2017 | 01:15 PM
airjunky I sent you a PM message
kip4234 is offline
Old 09-15-2017 | 02:01 PM
BUP
I have a like brand new one - with the regulator on the front. There is an issue with these rails that IMO needs to be address across the board whether they are brand or used..
I also have spare injectors all OEM - They all are flow tested, electrical tested, cleaned and balanced by myself or if one needs to have theirs checked as well.
BUP is offline
Old 09-16-2017 | 07:09 PM
I am wanting to fix all the issues with the rail. I have a good rail that Eddie Young did the fix on the injector hole that is to small and I have adjustable regulator on it. But I am wanting him to do the full bore feed fuel from both ends and he does alof of other things to it. You then don't use the rail regulator anymore at all. You use a separate big aeromotive regulator. I want to do this to a new or used rail that I can buy cheap.
kip4234 is offline
Old 09-17-2017 | 06:53 AM
Still needing to buy one of these
kip4234 is offline
Old 09-17-2017 | 02:19 PM
BUP
190 without regulator shipped. OEM stock like brand new.
BUP is offline
Old 09-18-2017 | 07:34 AM
I am really only wanting to spend $100.00 to $125.00 range on this as I can use my original one instead.
kip4234 is offline
