38' AVS speeds? >
38' AVS speeds?
38' AVS speeds?
Old 09-19-2017 | 01:04 PM
Panther's Avatar
Frank's Marine Service
Default 38' AVS speeds?
I built some engines recently for a 38' AVS. 565's making over 725HP,'
Curious what others have for power and what speeds you're running? Also, what gear ratio?
Any other AVS with ITS boxes and shorties?
Thanks in Advance,
Pic for attention.
Attached Thumbnails 38' AVS speeds?-21463302_1607474142638652_7596583154258508372_n.jpg
Panther is offline
Old 09-22-2017 | 04:01 PM
Panther's Avatar
No one looking to share their experience?
Panther is offline
Old 09-22-2017 | 08:00 PM
I have a '99 AVS... 540 Mercury Bulldogs, extension boxes and labbed 30's. Best I've seen is 81 with light fuel on one last blast late in the year when it was cool. Curious to hear the final numbers on the boat with your mills.
Shallow Minded is offline
Old 09-27-2017 | 12:04 PM
Panther's Avatar
Thanks for the info. Once the transom work is completed I'll be able to post some numbers.
Panther is offline
Old 08-13-2018 | 09:23 PM
Panther's Avatar
This past weekend the boat ran 87mph with a small chop, 6 people on board and full of fuel. AFR is also showing rich (12:1). Air temp was around 90 with high humidity. I think 90mph will be possible after some fine tuning with better weather and water conditions.
Panther is offline
Old 02-05-2019 | 08:44 AM
i have 89 38
pair of 547s , about 700hp
boat ran 82 , flat water , 4 people, full tank of gas
standard trs drives hyrod
4 blade 26
5600 rpm
hoping to see 85
some chop less peeple less gas
flashgordon is offline
Old 02-05-2019 | 11:50 AM
Panther's Avatar
I would think that you will make it there. A friend of mine has one with some 650's and he's seen 83/84 but low 80's consistently.
Our setup was 84/85 any day of the week and 87 being the top number.
We're shooting for 90mph this year with some engine upgrades.
Panther is offline
Old 02-05-2019 | 08:34 PM
Rookie's Avatar
Originally Posted by flashgordon
i have 89 38
4 blade 26
5600 rpm
hoping to see 85
That's a 38' straight bottom hull, right? So, it appears that the AVS is worth about 7-10mph?
Rookie is offline
Old 02-08-2019 | 06:48 AM
Talking straight vee bottom
yes it is a flat bottom ,,no steps,,,
dont know exact numbers , but have heard step bottom is good 5mph plus over straight vee...
flash .out
Old 02-15-2019 | 03:37 PM
i got 555 ci with 800 hp with xz drives boat runs 94
humpster is offline
