WPM Exterernal Steering Ram Seals >
Old 09-30-2017 | 10:16 AM
Default WPM Exterernal Steering Ram Seals
I have WPM steering rams and they both started leaking. Bought new seals, took the end cap off of the ram and removed the seals. There is one that fits inside the end cap about a 1/2" or son from the end that I cannot get the seal in. Has anybody experienced this. CP Performance says that one seal is really hard to get in so" we send them off to a guy and he does them for us. Anybody know how.. I tried for 2 hours yesterday and no go. the others seals are easy.
J.P. is offline
Old 10-11-2017 | 04:42 PM
Ayuh,.... A little late, but,....
Many times you can get those stuffed into place with wooden dowels, plastic picks, Popsicle sticks, 'n yer fingers,....
Whatever works,....
The seal needs to be semi-folded, 'n twisted to get it in there, then ya gotta maneuver it back to it's original shape,....
Not really any 1 trick to make it happen,....
Bondo is offline
Old 10-11-2017 | 07:50 PM
Rookie's Avatar
Seal install tool works well also...
Rookie is offline
Old 11-05-2017 | 12:48 PM
Got tired of trying yo get the seal in. Ended up taking just the seal housing to a hydraulic cylinder repair shop locally and left them. Shop called the next day said that they were ready went to pick them up and they said the seal I brought was to big and they were unable to get it to the groove. They provided the seal for both end caps and installed for $22.00 each. The seal kits I bought on line from CP were 109.00 each delivered 229.00 to my door. I should have googled seal repair in my area first, lesson learned. Thanks for the reply's.
J.P. is offline
