Is a prop slip of 7-8% realistic? >
Old 10-04-2017 | 02:44 PM
Default Is a prop slip of 7-8% realistic?
We recently tried a new prop and got significantly better performance.
Our previous props were producing 16-19% slip (24 and 26 Bravo I props. 24, 26, and 27 Hydro props)
Then we tested a 21 Pitch Revolution 4 prop, 7% slip!
It is such a dramatic difference, I have to question the results.
Boat details:
1993 26' Velocity
Bravo XR 1.5:1
new 21 Pitch Revolution 4 (LH)
new tach 5700 rpm
2 independent gps showing 70 mph
Sonic24 is offline
Old 10-04-2017 | 03:57 PM
It is realistic but maybe rare. I am at 8% as well.
5400 RPM
1.5 Gear
28P
87 MPH
TxHawk is offline
Old 10-05-2017 | 05:32 AM
Dave M's Avatar
Veteran: Navy
When I calculated the slip at WOT on the 24 Superboat I owned, I was getting 9-10%. That was under ideal circumstances.
Dave M is offline
Old 10-05-2017 | 06:42 AM
t500hps's Avatar
21 and 42 footers
After prop experiments I went from 18-19% to 10.5% in a 382 Formula......and 10 hours later trashed an outdrive. Slip isn't always a bad thing
t500hps is offline
Old 10-05-2017 | 07:04 AM
Boat details:
1993 26' Velocity
Bravo XR 1.5:1
new tach 5700 rpm
I had a 25 revolution on a Baja a few years back. It was like I put 27 pitch prop on. They definitely grab some water.
veloc410 is offline
Old 10-05-2017 | 07:09 AM
Im getting quite a bit of slip on my props now and was worried about the same thing if I went to 5 blade. Twin 572's 30 pitch 4 blades sl4 and bravo one outdrives . After what you said I think I'll stick with the 4 blades .I get a lot of slip at cruise speed say 40 mph
veloc410 is offline
Old 10-05-2017 | 07:25 AM
SB
I agree.
SB is offline
Old 10-05-2017 | 08:17 AM
t500hps's Avatar
21 and 42 footers
Yep, twin 540's/700 ft/lbs TQ. 32P bravos, 18-19%.........28P full size (15 5/8) maximus were 10.5%. Cruise speed increase was great (WOT speed dropped), but the drives didn't survive.
t500hps is offline
Old 10-05-2017 | 01:38 PM
Sometimes slip numbers are wrong.
example:
I switch from one 25 to another.
my slip numbers go down from say 13 percent to 9 percent.Looks good on paper but if my new prop actually has 26 instead of 25.Or my old one was actually 24 instead of the 25 it said then my slip numbers are almost identical to my old prop.
Warship2k15 is offline
Old 10-05-2017 | 05:23 PM
T500 .Is that a fountain. I see step transom. How far below the deadrise are your propshafts??
veloc410 is offline
