off shore style throttle control stiffness >
Old 10-05-2017 | 01:59 PM
Default off shore style throttle control stiffness
Hi,
I have the split - gear and throttle levers - in my Advantage Victory. Increasing throttle is very stiff, but on the return its super smooth. It seems that maybe the stiffness is a design intent...is that the case?
Is it possible to adjust this? My wife has a hard time pushing the throttle forward.
PowerAddict is offline
Old 10-05-2017 | 02:10 PM
Disconnect the cables 1st before you do anything
class6 is offline
Old 10-05-2017 | 02:51 PM
Maybe they purposely design that way to keep wives out of the driver seat. Lol. I agree with class6. I'd detach cables in bilge and see how they react.
getrdunn is offline
Old 10-05-2017 | 04:16 PM
they should have about the same resistance in either direction.....
phragle is offline
Old 10-05-2017 | 04:23 PM
What kind of throttles are they. The ones I've had and been into had resistance adjustment however resistance was set the same for either direction.
getrdunn is offline
Old 10-05-2017 | 07:10 PM
It sounds like someone may of put an overly stiff throttle return spring on to compensate for a crappy cable.
Baja Rooster is offline
Old 10-05-2017 | 07:21 PM
or just bad cable in general. I could see where the cat whiskers on a bad cable could snag one direction and not the other.
This should be an easy process of elimination....
getrdunn is offline
Old 10-06-2017 | 10:43 AM
I'm pretty sure its a Gaffrig.
thanks for the tips so far. I guess it could be the cable only in 1 direction like you mentioned. It's just odd that the stiffness going forward is so consistent every time. I'll play around with it.
