Which filler to use?
Old 10-09-2017 | 07:44 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Which filler to use?
Got to cut out and glass in a new cleat backing block do to leaking screws. . Using 3/4” marine plywood and WS epoxy I have. Do I use a high density filler to bed the block in or can I use a general filler such as colloidol silica? I want to use the filler to also fillet the block around the edges for the glass to lay over smooth. Have read the WS 404 isn’t for filleting. Looking for a 1 item does both of possible for this 1 single repair. Thanks
US1 Fountain is offline
Old 10-09-2017 | 09:01 PM
glassdave's Avatar
Neno the mind boggler
yes, bond in with WS high density i think its 404 and it will be fine for the fillets as well. 404 would not be good for fillets on finish work but if your glassing over its good.
08 OPA High Points Champion
glassdave is offline
Old 10-09-2017 | 09:07 PM
Ginger or Mary Ann?
Thanks!
Old 10-31-2017 | 11:17 AM
Yes thanks Dave good info I appreciate it also.
87MirageIntruder is offline
